Results 1 to 10 of 15
Thread: MSD Boostapump FS NIB
    Mar 2006
    Mesquite
    Also can you explain how this works? I'm out of fuel at a little over 5000 rpm...wondering if this might solve my problem.
    All I can find online is it increases voltage to the pump as boost increases. Does the higher voltage make it actually pump more?
    Apr 2005
    Yup. more power spins the pump faster = more pressure
    Gone, but not forgotten!
    Blue Springs, Mo
    As the boost psi comes up the msd box will increase voltage to the pump. Just like a electric motor. More volts you put to it faster it spins. This will also help with loss of volts through the factory wiring goin to the pump. The two long lead wires, (+) (-) runs from the msd box to the pump. Decent size wire too.
    2004 silverado rcsb 2wd cammed 6L, 3.42's, Hydroboost swap, 4l80e w/hd-2 and yank 3200, twin intank pumps, 60lb injectors, trick hot pipes/MP T76
    Oct 2008
    Houston
    They sense when the engine is making boost or at certain rpm levels
    and increase voltage for that short time to increase pump output.
    You dont want to increase pump voltage all the time, only when you
    start to run out of fuel under normal conditions.
    KenneBell really clued into this first with their "BoostAPump"
    Its a great way to get an extra 10-20% out of a fuel pump for the short
    burst you need from it "up top"
    Jun 2007
    My aeromotive fuel pump controller does the same thing basically.Boost voltage above 3 k rpm and pushes more fuel ,also doesnt make the f/p work as hard.bumps my fuel pressure 3-5 psi at 3k +.
    Blue Springs, Mo
    I will be putting it up on ebay tomorrow if no one is wanting it.
