Originally Posted by
LamboDoNoMo
so uh what the heck is it
REALLY?get it lambo ,it a diag tool and you can clear codes on demand,it plugs into you obd,gives you alot of info iats ,coolant ,kr,oil pressure ,mph,tons of stuff,well worth it ,i think i pd 400 bucks.look it up.
