The only time you'll get pressure in there is when the tank is filled half way or less when cool then the tank and the air and fuel inside gets significantly warmer causing a spike in pressure.
Most likely you're hearing vacuum. The tank is put under vacuum by the EVAP system which draws fuel vapors back through the charcoal canister before venting them to the atmosphere to reduce emissions much like the clunky crappy gas hoses in emissions counties.
This is the system that will turn on the SES light if you leave your gas cap loose (P0440 and P0442) or when the the canister and vent valve get plugged with dirt road dust (P0446).
HTH
