Technically they sit in the same place. The difference is that the 80 and the bigger T/C is longer.....
True, I don't know why I was wording it like that.
So, I found his post on cross member modification HERE. Says he moved it back about 2.5" to keep the engine in factory position. I have no problem having the engine moved 3" forward to accommodate the 4l80E. I plan to run electric fans so I should have plenty of roomDoes anyone know If any motor mounts will help me accomplish this? I'm not much of a fabricator to say the least
1998 2Dr Tahoe 6.0/4l80E Swap
1998 Camaro Z28 LT's/ORY
1997 Dodge 2500 Cummins
