Low 12's with stock stall and cam??!! WTF??? That thing is going to be crazy when you get the stall and cam put in!! Nice times!!
I have no idea either man. Somethings not right though, my dyno numbers are low and my ET sucks. Must be the tuning![]()
Wow David! That is Awesome!
sick time man...I wonder what kind of times I can get. I really wanted to be there but family comes first...
●01 silverado x-cab w/5.3 ● STS GT-67 ball bearing turbo kit(relocated under cab)● Comp 918's ● Comp Hardened Pushrods ● Comp Cam 212/216 .557/.561 114 lsa● 42lb injectors●Walbro 255lph inline●OBX Intercooler● YANK 2600● Nelson SD Tune● Magnecore 8.5mm wires● STS meth Injection●Comp valvesprings● 05' e-fans w/ 34" radiator● ARP rod bolts and headbolts● NGK TR6 plugs● Eaton Posi● DB Rods bagged 4 link● FLT lvl5 4l65e● Apexi AVC-R boost controller ● z06 6 piston brakes front/4 piston rear 14" rotors ● Goodrich SS brake lines● powdercoated frame
+1 ^^^^ Lololololololol![]()
Great runs man. Wish I could have been there.
2006 K1500 Vortec Max CCSB 6.0 4.10's, Nelson SD Tune, Trick Turbo kit T76 @ 10psi, 60lb/hr injectors, 4" duramax exhaust, snowmeth stage 2 kit, FLT Level 5 4L70E, Vig 2600, 40K trans cooler, 265/70/17 BFG All Terrains. 13.0 @ 102mph 1.8 60ft
Truck looks awesome in person david. Love the sound of it. Good luck hitting 11s soon
EXCELLENT and judging from that tree in the vid you were running into a pretty good headwind as well Congrats bud!! I think on a calm night, good traction and a small progressive shot off the line you could see a high 11
2007 SRT8 Jeep Grand Cherokee
