what should timing be set at with a scanner on a 1997 c1500 5.7 350?
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
The question and answer may not match here.
If it's an R 350 (stock type) timing is not adjustable by turning the HVS like an old distributor. Timing can only be changed in the 'puter. Twisting the HVS will only throw off the CMPS and the offset.
If that's what you meant in the question, I apologize.
man i am just trying to figure out why in the hell my truck is detonating, no matter where i get my fuel from. i have even ran a quart of water threw the TB to clean the carbon up and i still am having this issue!!!![]()
There is help out there somewhere...
Maybe there's an update for your PCM, like a newer OS or fix?
Nelson Performance
NP on Facebook
Youtube Channel
