Originally Posted by
07_Silverado
block, crank, pistons, rods, oil pump, truck intake, lq4 heads with rocker arms valves valve springs and push rods, coil packs, and im sure what else. it was a complete short block when it was pulled out, then he acquired the heads, intake, and coil packs and other things.
the heads on the lq9 and lq4 are the same (317's) the diff in the motors were rods and high compression...if that motor is that complete you need to jump on it....if anything you can flip it for about $500 in your pocket
