When is it? This Friday. I gotta work Friday.
I think David Fuentes wants a retune before he races Jeff Painter so he can take advantage of his new go fast parts.You guys crack me up!
Play nice Jeffy...
I think Jeff's balls grew when his truck got faster.....
is the install tomorrow???
●01 silverado x-cab w/5.3 ● STS GT-67 ball bearing turbo kit(relocated under cab)● Comp 918's ● Comp Hardened Pushrods ● Comp Cam 212/216 .557/.561 114 lsa● 42lb injectors●Walbro 255lph inline●OBX Intercooler● YANK 2600● Nelson SD Tune● Magnecore 8.5mm wires● STS meth Injection●Comp valvesprings● 05' e-fans w/ 34" radiator● ARP rod bolts and headbolts● NGK TR6 plugs● Eaton Posi● DB Rods bagged 4 link● FLT lvl5 4l65e● Apexi AVC-R boost controller ● z06 6 piston brakes front/4 piston rear 14" rotors ● Goodrich SS brake lines● powdercoated frame
yeah it was today. took me about six hours. It was actually going a lot smoother then I thought until the second to last spring.. the keeper fell down somehwere outside the engine. I looked for about an hour and couldnt find it so I said screw it and jon gave me another one.
Crossed my fingers and started the engine hopign it hadnt fallen inside the head.
Drove about an hour back to my place with no problems.
Thanks guys for all your help!
haha it was yesterday. there is no way im going to be productive today at alllll
so now are you going to turn up the boost?![]()
