BADD A$$
Now you wont even need a radio LOL. That $hit is the best music.
I don't think I could do that every day, every other day and twice on sundays would be![]()
BADD A$$
Damn fool...sounds bad arse! Not be the a-hole, but is the driver's side cutout positioned right at the wiring of the pass side? The hot exhaust might cause premature electrical failure??? Just asking...it might just be that the picture is distorted and I can't see the depth of it all...
you are right about the heat I see floor boards with holes, I took mine and added a short turn down to it, blows toward the ground, looks very good like the side tips
Its close but not as close as the picture makes it look...i was a little disapointed with the placement of the driverside cutout...but untill the day i have every tool i need and a lift i will just have to except the fact that not everything will be exactly the way i would do it.
Thanks guys for all the positive comments
05 RC, LME 6.0, 243 Heads, LSA Rods, 11:25 Forged Pistons, Cam Motion Custom Grind, 4:10, Eaton LSD, Narrowed Rear-end w/ Chromoly Axles, Pacesetters LT's, SLP Loudmouth II Mufflers, Volant CAI, Yank SSTB3600, Bosch 42 lbs inj's, G-Force Tune, FLT Level 4 Trany, Belltech 2/4, Times: ?
Would you happen to have another sound clip?? I've heard a single in/out 3" spintech and I didn't like the way it sounded, I need something to convince me to spend the extra cash for going with an xpipe and duals![]()
That sound sweet bro.. I def need cutouts now
I have my switch located in the plastic at the bottom of the drivers seat.....just reach down with my left hand like power seats and open into full race mode....lol......ran the wire through a grommet in the floor board right close to where the switch is located....worked out really nice! I also ran the wire through the cab brace tunnel so you cannot see the wire under the truck until right where the cutout is....worked out really nice!
2000 SILVERADO RCSB STOCK LS1, CAM, BOLT ONS
7.93@85.21
12.61@105
http://www.ls1truck.com/forums/my-ga...silverado.html
Check out my PhotoBucket Page!
http://s174.photobucket.com/albums/w114/carfreak07/?
BIG BURNOUT VID IN THE SS!!!!
http://videos.streetfire.net/video/7722e80...d29a3318cde.htm
wth! did i miss something is gator back in business, if so, great, glad you could join us again!
ttyl,
allen
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
