Results 1 to 10 of 17
Thread: is this a good cam for NA and N2O ???
    Kilgore, TX 75662
    Quote Originally Posted by Slimsilverado View Post
    Yea i feel ya on that Jeff i like a rumble at idle.... The GTE2-3 cam has 207 / 220 with 571 / 578 with 118.5 lsa... That cam would idle like a pussy cat the question is good is 118.5lsa for spray??? Would the big lsa make a difference once the N2O is applied?
    To get the most out of the nitrous, you want to keep as much of it in the cylinder as you can. To do this, you need a wide LSA. 118.5 is very wide!
    For a naturally aspirated cam, you want a much tighter LSA.
    Since it isn't a daily driver, I would not hesitate to go with at least a 3600 stall and 4.56 gears (since most trucks have relatively tall tires.) For a stock head 5.3L non-daily driver that wants to occasionally spray, consider something with the intake duration around 220 degrees and an exhaust duration over 230.
    This would work very well. LS1-GT7 208 / 230 .554" / .546" 1.7 ratio 121 LSA
    The Thunder Racing TR Blower cam or CheaTR or LS2 CheaTR would work well also.
    ff_jeff Guest
    Quote Originally Posted by AdioSS View Post
    Another thing to keep in mind is when you spray, you want as little backpressure in the exhaust as possible. IF you put a high flow exhaust on, you could see like 20hp more with nitrous than a less free flow system. Here is a link on a good read Nitrous Tuning Tactics - Popular Hot Rodding Magazine
