Zeake,
In your original post you said you got an 02 PCM, relocated IAT, and 2Bar Map sensor. You didn't hook up the PCM, But did you install the 2 bar MAP sensor without setting up your PCM Map scaler table?
Jeff
Zeake,
Jeff
