Results 1 to 10 of 14
Thread: 2003 NBS V6 V8 Swap
    at my house
    Im pretty sure you dont need to convert to DBW in your 03. Unless it was the earlier 03's and they might have used a cable setup
    My truck is a V6 DBC
    Quote Originally Posted by jtaliaferro View Post
    Ohhh ok. Its not that hard to convert since u have the new engine
    at my house
    So do you think a DBW conversion is going to be my best option?
    What does the DBW harness consist of?
    Does it run through the under hood fuse box? (I know the ECM harness has the wiring for the Electronic TB, I am wondering about the harness from the tac to the pedal)
    Can a 2001 0411 PCM be flashed to work with DBW?
    Well since you have the newer motor yes. Im not sure what the harness consists of, but I dont think its that much of a pain to swap. Does your old setup have the return style fuel rail because u need to make sure you have that on the new motor
    at my house
    Yes the fuel system is complete
    Nice you gonan run steel braided lines or stick with stock?
