Is there a way i can tell what gears (Stock) I have from the Vin #.......I am due for gears soon so if I have 3.42's should I go to 3.73???? I do have the
I6TB TC installed with a Nelson Tune and K&N ??? Any suggestions..Thanks guys
2000 ECSB, K&N CAI , 2/4 Drop , 40 Series Flowmaster, I6TB TC, and Nelson Tune.....Need Gears before it blows!!!!
Do you still have the glove box label that shows all the install codes listed? Look in there and the factory installed gear ratio code will be listed. The break down of the gear ratios is listed here somewhere.
Look for the GT code...prob be GT4 which is a 3.73 gear.
Go here to confirm.
Perfect!!! I have 3.42's.....Do you think i should go to 3.73's?....How much will that affect my MPG's. I already have a TC installed and am wondering if it will be overkill? Input wanted???
i have had 3.42s.430.s and now 3.73s....i think 3.73 is the best so far and my MPG is still good
Vortec Performance Tuned
IMHO, 3.90 gears would be a good set.
