Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 41
Thread: OBS chevy LSx wiring
  1. #21
    May 2004
    I extended my wires and put the pcm on the passenger side and put my relays and fuses on the drivers side. Pretty much all plug and play.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
  2. #22
    Hutto TX
    what is the relay/fuse block item on your pass side fender nitrous?
    1991 Silverado ECLB
    LM7-T56
  3. #23
    phoenix az
    nitrous what did u do for the gas gauge did use the stock pcm ?
  4. #24
    May 2004
    The small cover on the right houses both LS1 fan relays and the cover on the right houses an extra fuel pump relay, extra A/C relay, fan 1 and fan 2 30 amp fuses, an extra 10 amp fan fuse, an extra 20 amp fuel pump fuse, a 10 amp PCM battery fuse, a 15 amp A/C fuse, an extra 15 amp pcm ignition fuse, and 3 extra fuses for fuel injection if needed. I made the small plug and play harness with exra features to use in other vehicles.
    The gas gauge is standalone from the PCM so the sender is hooked up just like factory.
    97 GMC, 2002 LS6.
  5. #25
    Oct 2003
    Quote Originally Posted by NITROUS View Post
    Nice relay/fuse centers. And where did we source these from?
  6. #26
    Dec 2004
    San Antonio, TX Area
    Very nice, can't wait to get mine started.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
  7. #27
    phoenix az
    on the 98 it uses the pcm for the gasgauge
  8. #28
    May 2004
    beater6.0, your talking about the purple wire pin 9 on the blue connector right? I don't know why it's needed to be honest unless the sending unit has changed in 98. It's not used on 96-97 and I have a set of 98 and 2000 tahoe gauges that both work in my truck without that wire. Let me browse through the factory manual and see why you would need it.
    97 GMC, 2002 LS6.
  9. #29
    May 2004
    What I see is that the purple wire goes from the VCM (Fuel gauge level) through the C100 to the cluster (fuel gauge). I'm not sure why you would need this because the diagram shows the purple wire to go to an external fuel gauge and from there to the cluster. I really don't think you need this wire from the looks of the schematic but I could be wrong.
    97 GMC, 2002 LS6.
  10. #30
    phoenix az
    its been awhile but itried bypassing the pcm but noting happened but at the same time sendingunit went out so going to worry about another day
