Results 1 to 10 of 38
Thread: Stock LQ9 Parts FS
    Feb 2005
    Austin, Texas
    On patriot springs you have remove the valve guide seal to put the new style seat on, if there is a bunch of debris built up on top of the valve guide then it can easily become wedge in there especially after the motor heats when the tolerances get tighter therefore gaulding the valve guide, valve stem or both causing a squeeking noise from too tight of a tolerance between the two surfaces. You are the one who had to part your truck out and sell it a while back to move out of mommy and daddys place or so you posted. On the contrary I never had a problem with you until a while back, the first big instance I remember was your boy telling my you wanted my LS6 block and that I should PM you. I had someone local offer to come pick it up and and you hadnt said anything to me about getting the block from me so I sold it. You got your panties in a wad and proceeded to send me a rash of ****ty PMs over on pt. Second the original noise on daniels truck was not coming from up front on the accessories drive, he and I both climbed all over that motor and it sounded to be from the top end. There was no coolant on the belt when I watched daniel try to guess the routing of the belt How the hell would I hit the alt hard enough to hurt it while changing the springs, it would take a hammer hit or something to really screw it up. A noisy alt like Daniels most definately can be a problem its coming from one of the bearings, I believe its the rear one where the cooling fins are at, if not replaced it could sieze leaving him stranded and possibly eating a belt in the process. So please tell me how a noisy alt like his is of no concern. You have second hand knowledge of the problem with his truck, you werent there, I may not have the most experience on this board but Ive been around long enough and am familiar. Honestly I could give a **** less, you didnt see how nasty daniels motor was, I personally believe it was a valve guide issue after seeing the debris that was in his motor and how nasty it was, either way his truck is running and very good and thats all that matters. I dont care to converse with you via PM or telephone about our issues, I dont care to be your friend just keep your posts out of my threads or taking shots at me in any other threads and I will do the same.
    ok guys enough, we don't need to be fighting here, we all have or own opinions and its great to express them but there is no need to bash one another if you disagree. but i do have to say you both are taking the mature route in this and not flaming around like idiots.
    sprayed99 Guest
    Quote Originally Posted by 1slow01z71 View Post
    no dip $hit I have lived on my own for over 8 years. I have had my own home for almost 3 years now. I now manage a broker/dealer and have another company that I have started. My finances are none of your business period! I parted out my truck because it was under the company and my father filed bankruptcy on the business and the trustee seized the truck. But of coarse that is none of your business. Please read above jack ass I never mentioned you in this thread and wasnt taking a shot at you. Get off your high horse and grow a few inches so you can get out of your short man syndrome.
