Results 1 to 10 of 15
Thread: lt1 swap into 87 3/4 4x4?
    Jun 2007
    Post
    i have a 1987 chevy 3/4 4x4 and want to do a resto mod on it and for the engine transmission i wanted to use an lt1 4l60e or 4l80e combination. i'm trying to find more information on what i'll need to do this swap into my pick up. i've read about guys doing this with 2x4 model trucks similar to mine but nothing thats a 4x4. any help would be appreciated. i'm just trying to do some research before i go ahead and get into this project.
    Jun 2007
    guess it's kinda a crazy idea huh?
    Personally, I would not waste the effort with the LT1 engine. That engine was only made for a few years and parts are pricey. Get a Gen3 engine with the newer technology and better fuel mileage. They never put LT1 engines in trucks at the factory so that makes the conversion even more difficult. The newer 5.3/6.0L engines are the way to go and you get a better transmission to go with it.
    Jun 2007
    ok, so if i went with a 5.3/6.0L engine, would the motor mounts have to be modified? how hard would it be to come across a vehicle with that engine in that's trashed, how much money ruffly would i be looking at?
    Price depends on your shopping abilities and what's available in your area. You need to get Gen1 to Gen3 adapters, available on Ebay for $40.
    Jun 2007
    ok i'll have to check that out. what about the trans? probably have to get some sort of different crossmember made.
    the earlier Gen3 4x4 setups are probably going to be your best bet. Check around and see if any of them still have the manual linkage setup.
    Jun 2007
    tulsa, oklahoma
    i have a 4.8( was suppose to be 5.3) didnt check serial number when i bought it. i have a lt-1 in my roadster, the 5.3 complete change over, motor tran, wiring comp was cheaper than the lt1. just alittle more work to install, but 5.3 lot better tourque than lt 1
    1987 jeep wrangler, 1999 LS 1, 4l60 231j transfercase, dana 30 frontend ford 8.8 rearend 3:73 gear ratio. sandersons shortie headers, 2.25 inch exhaust into 3 inch flowmaster muffler.
    plus the LTx do not like water.. and being a 4x4 they kinda ooozzz their
    way to the wet stuff...
    a tuned 6.0 genIII and your th400 would be strong combination, less
    work to get it running. 80e if you want.
    airdeano
    Jun 2007
    tulsa, oklahoma
    the lt-1 distributor is on the front of the engine, and it will get wet and the it is very expensive to replace.the 95 -97 are vented and that helps alittle bit, but still a big disavantage, 5.3 or 6.0 wins easily
