Results 1 to 5 of 5
Thread: used gears
    Jul 2006
    College Station, TX
    I received some used gears for cheap and after inspecting them i only saw a couple minor problems. One the inside of the ring gear 4 teeth have minor flat spots that i believe can be machined out. And on the pinion only 1 tooth has a minor nick in it. Also i believe these can be machined out. These are 373 gears with 50k on them and came out of a z71.
    What do yall think?
    2004 EXC Silverado 6.2L
    Mods:
    DBYRD Guest
    i know its obvious, and im not gonna have ur answer, but pics might help.
    Trash them. Damaged teeth destroy gears and diffs, too, if on the tooth contact faces.
    Jul 2006
    College Station, TX
    ill get yall some pics posted. They are very small. They look like it has been wore in those couple spots. I am talking about 1/2 centimer spots. They are on the very tip of the tooth on the inside of the ring. Very small.
    Mods:
    May 2004
    If you have to do any machine work on gears do like RHB says and chunk them!
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
