Results 1 to 10 of 10
Thread: z06 cam in 6.0
    Oct 2006
    Provo Utah
    Hey guys I am new to the sight. I have a 1990 ss454 pickup. I am about to drop in a 2004 6.0 motor and had a few questions. I have a z06 cam and springs that a friend gave me and was wondering if it would be worth the swap? The engine is sitting on a stand right now so should be a way easy swap. The engine is a lq4. Also did any of you use the factory engine harness? If so how easy was it to make it work? Any help would be greatly appreciated.
    Thanks
    Shawn
    Welcome Don't know and no.
    Sep 2004
    The LQ4 with a Z06 cam is SWEEEEET!
    I had that combination originally and switched to a comp cam. I'll be putting the Z06 cam back in soon.
    It will be a simple swap on the stand. Go for it.
    No more trucks, but this is what I used to have. 2000 GMC Sierra, 6.0L-LQ4, Built 4L60, LS6 Cam, The Other Guys Headers, 3 inch exhaust and 7 chamber flowmaster, 43lb injectors, Nelson Tuning, Drop - 3/4 McGaughys Spindles, Bell Tech Shackles & Hangers. Best time 13.59 @ 106
    Jan 2005
    Conway, AR
    That would be a sweet setup in the 6.0, I have it in my 5.3L and love it.
    Oct 2006
    Provo Utah
    Did you guys install the cam straight up or 4 degrees advance? Also any loss of power on the bottom end?
    Shawn
    Sep 2004
    I installed mine straight up. With an LQ4 you won't notice any loss in low end, but it will come hard around 3500 rpm.
    Jan 2006
    Las Vegas, Nevada
    I'll answer the factory harness question.
    Yes, I am using a modified stock harness and no, it was not hard to do..... The Gen III truck harnesses are easy to pull apart and modify, if you have the schematics from the factory service manual. Please note, I did not say Chiltons or Haynes or the like. What I am referring to is a set of Service Manuals from Helm. Alternately, a digital set is usually available on Ebay or an online subscription to Alldata will get you the pin-out information you need.
    1965 C-10 shortbed stepside, 2003 5.3/4L60E conversion. Power steering, tilt wheel, power front disc brakes, 3.73 one wheel peel, 2.5/4 inch drop, relocated fuel tank and battery, 2002 Silverado buckets and console. Swap Pics
    1968 Camaro 95LT1/4L60E lots o' mods Web Page
    1961 Corvette project.......... C-4 suspension and brakes, 02 LS1/T-56 awaiting installation Pics
    Apr 2003
    Mansfield, Texas, USA
    Throw those TBI 454 heads in the trash and call up Canfield for some heads. You'll glamor at the gains.
    Nov 2006
    <div class='quotetop'>QUOTE(chrisj6 &#064; Oct 15 2006, 12&#58;20 AM) [snapback]69463[/snapback]</div>
    how much of gain did you notice does it pull more at topend
    Jan 2006
    I&#39;m interested to know the gains also. I have been thinking about doing this. I think once I go to 10lbs of boost it should make a nice diff. without being cammed too heavy.
    05 Escalade STS GT67 5Lbs
    06 G35 6MT SEDAN
    92 Gmc Typhoon # 46 (Sold, gonna miss her)
    92 GT Basic Mods
