Hey guys Ive been pretty busy this last couple of months but is time to get back on track and get this truck running.
Is there a chance my PCM could be bad? Theres power going to it and the motor cranks. There's no spark and the fuel pump will not kick on unless I hot wire it. All those things are controlled by the PCM and the damn is grounded right, theres no break in the lines, no blown fuses. This is all I can think off, I even took off the wiring harness and went through everywire and every pin in the PCM.
Well in another note Ill be a civilian come monday the 7th of August and I will be moving back to the great state of TX. Thats the big rush in getting this thing running. Ill will be sending my PCM to Allen first thing monday morning. Well Ill talk to you guys later.
causing the injectors not to function at full capacity. Took the fuel pump, and ran off a seperate circuit, then all fired up as should. Just a thought. Good luck!
