The LS computer doesn't send the correct fuel level signal for your cluster. You need a fuel segment swap with your tables flipped. Your engine coolant temp signal will come from the original sensor that was in your 5.7- I suggest turning it down and using an M10x1.5 die so it will fit in the place where the head coolant plug is. Fuel pressure gauge can be hooked up to the LS pressure sensor. PRNDL will need splicing-i couldn't get mine working fully yet.
