Results 1 to 10 of 40
Thread: 98 Suburban 4wd 5.7 to 01 6.0L questions
    Been lurking for years and have learned a lot, but not enough!
    I'm in the process of putting a 6.0L in my 1998 Chev Suburban 4wd. I was planning on removing the stock 5.7 computer, pulling the required pins from the old harness and placing them into the 6.0L computer harness.
    I'm at the point where I'm pulling the pins from the old harness when it dawned on me that I have NO info on what pins I need to pull for the 4wd system! Or can I even do it. Maybe I'm stuck with using both computers because of the 4wd?
    I have a stand alone harness for the 6.0L ready to go....
    Please advise
    84 K3500 Suburban, 05' 6.0L, forged, balanced, studded, boosted, 4L80E, NP205, D60/FF-14B, 37x12.50's.
    98 K2500 Suburban, currently undergoing 6.0L conversion
    Jul 2005
    A few down from your post
    http://www.ls1truck.com/forums/lsx-t...rger-swap.html
    peace
    Hog
    97 GMC 2wd RCSB 5.7, s10 2700 footstall, Hooker 24621hkr LT's , 2.5" cats dual 4"pipes exit B4 pass. side tire, custom driveshaft 3.42 G80 FIPK MAF descreen GM/Mercruiser Marine intake manifold 29lb LS2(EV6) injectors Ed Wright PCM(best mod), LT4 KM 14.8@94mph 2.007 4000lbs 122mph
    I looked through that whole thread and saw nothing about the 4wd issue I have, am I blind? I have the same info that thread has on pulling pins, just nothing about the 4wd.....
    Sep 2012
    Quakertown, Pa.
    Depending upon what you have, you will need to run either one or two wires to the new PCM.
    The following are for Suburbans without Auto Trac
    Circuit 1694, gray/black wire, pin 23 of C-4 connector
    Circuit 1695, black/white wire, pin 19 of C-4 connector
    The following is for Auto Trac
    Circuit 1695, Black/white wire, is the front axle switch wire and goes to pin 19 of the C-2 connnetor(red or green, depending on year) of the new PCM
    Circuit 1694, gray/black wire, is the 4 low signal wire and goes to pin 16 of the C-2 connector.
    John
    May 2007
    Oak Forest, Illinois
    A small reworking of your stock 97 harness with the addition of 10 wires will run the Gen3 engine. You don't need a stand alone harness or two PCMs.
    Jeff
    98 GMC RCSB 2wd, 100% internally stock 305, w/twin T-3 junkyard turbos,Ramjet intake w/42lb inj,12200411 PCM. 4675lbs w/me in it. Best time in 5 passes 13.01@110
    I understand that the old computer will run the LS engine - I have HP tuners and I've already licensed the LS computer, to use the old computer I'd have to license it for another 100 bucks. Would the extra 100 bucks and adding the extra 10 wires be easier than using the LS computer in my case? I do have another stock LS harness that I could salvage the extra wires and connectors from. I believe I have the auto transfer case - I need to check for sure....
    May 2007
    The 98 Black 4 plug PCM will not run the Gen3 engine. What you would do is repin the 98 harness for the Gen3 PCM and install the additional 10 wires to the harness. There are a few wires that also need to be lengthened. I got your P.M.
    Jeff
    Got it - I was thinking backwards! I assume that I would just remove the old injector harness plug and add in the new style connectors for each cylinder....
    I'm pulling the old engine today and going to try to install the 6.0L, thanks for your help
    May 2007
    Yes, That is one of the things that needs to be done.
    Jeff
    Do you have the info I need to do the harness conversion? I'm liking this idea much for than merging the two harnesses or running two computers.
