Results 1 to 10 of 41
Thread: 95 RCSB to LQ4/4L60e
    Jun 2010
    Bay Area, CA
    95 RCSB to LQ4/4L60e (56k Heavy)
    This 95 is a project that I'm working on for a member from another board that I'm on. It started life as a 350TBI/4L60e and I'm swapping in an LQ4/4L60e. Trans will be updated with the Gen III/IV style 4L60. Using a Nelson Performance Harness, Transdapt Adapter Plates, and everything else needed for a Smog Legal Setup. I'll go into detail with the swap and take pics along the way.
    Getting ready to pull the engine
    Got a little help from a friend
    Me removing the last little connections
    All Gone...
    2000 Camaro SS M6 - G5X4, LT's, 4.11's
    1989 K5 Blazer 350TBI/700r4
    Jun 2010
    Bay Area, CA
    And the Degreasing Begins...
    A little better...
    badass man...that a SS truck?btw camaro on sig looks sick..what color is that
    Jun 2010
    Bay Area, CA
    LQ4
    Transdapt Mounting Plates
    Dropping it in for a test fit
    Looks Right at home
    Put the intake on to see how it would look
    Looks like a pretty good fit...
    Jun 2010
    Bay Area, CA
    Quote Originally Posted by CHEVROLADE View Post
    No it isn't. Thanks it's a HOK Kandy. Close to JSB from the Vette. Nice truck in your sig too!!
    Jun 2010
    Bay Area, CA
    On the Transdapt Plates, it seems like the bolts that bolt the factory 350 mounts to the adapter plates are too long, have any of you ran into this problem before?
    Also, Not sure which wires on the old Harness to remove and which to keep. I've searched all over. I know that the Nelson Performance Harness has a few connections that need to be hooked up but I wasn't 100% sure about those as well. If anyone can help it'd be greatly appreciated. I'm going to try to figure out the Wiring tomorrow.
    Matt
    all the wires for the new harness can be hooked into the leads coming from the main harness going into the firewall on the driver side firewall. I can't remember if I documented the ones I used in the "current top secret project" topic I made when doing the 93 conversion.
    Feb 2011
    Barnwell, SC
    I had the same problem with the transdapt plates. I ground the bolts down til they fit right.
    Jun 2010
    Bay Area, CA
    Cool thanks I'll check out your build thread
    Quote Originally Posted by bstill View Post
    I figured that's what I'd have to do. Thanks
    Nov 2010
    Durant, Ok
    I wouldn't cut any wires until you get everything working as it should. Just zip tie them all put of the way, that way you don't accidently cut something you need. I traced the wires one at a time and pulled them out of the way
    Josh ----- 95 Z71 ecss -6.0 swap finished 10k miles ago, nelson tuned, built tranny, 2800 converter, 4.56s truetrac
    2000 z28 a4 longtubes, true duals, ported throttle body, ls6 intake, slp lid (lost in divorce lol)
    79 camaro small block street car 11.60 @ 116 (sold)
