just curious what you guys mean by swapping to quality fluid, as in clutch fluid or trans fluid, and what kind do you use to make it shift better or perform better.
Any advise is welcome thanks in advance
4.8\5 speed\3.23's\Airaid TBS\Flowmaster 40 Series Muffler\Volant Power Core CAI w/ Scoop\0/2 Drop\
Mine has RP SynchroMax in it. If you want it to shift nicer pick up a Centerforce clutch. As far as clutch fluid, just flush it fairly regular. I believe it uses dot 4. Can't remember.
haha may have to change the clutch fluid. i put dot 3 in it at about 33k miles. did you notice any difference with the rp fluid?
Couldn't tell you. I did a whole bunch of stuff all at once, built 5.3 replaced the 4.3, new fluid in the trans and hydraulics, new clutch.
Do the drill mod or replace the clutch line. This alone will make a huge improvement.
2014 Xsport- 3.5 Eco boost
412 Motorsports
I have a centerforce in my truck and it feels great. Just curious Quick. what is the drill mod?
1992 rcsb. Stock lq4, 85mm mass, e fan, lts true duals, magnaflow, t56, tru trac, 4.10s, slap bars
412 Motorsports
