^Ricky's Sweet PS Skilz
My only issue with using used ones is they tend to be corroded pretty significantly. At least that's how used ones I've seen are.
most are on the outside, but on the inside they work fantastic. people re-use stock manifolds for turbo kits. Dont worry too much about it.
Ok. That's good to know. Thanks.
 Member
						Member
						If 5.3 ones fit I'm pretty sure I still have my stocker's @ my parents and your more then welcome to them for $40 bucks. I'm in ventura so if you want to venture up here they are yours.
05 Gmc Sierra RCSB 5.3 - Vortech V2 Intercooled, BBK 80mm TB, Edlebrock shorties, Custom built 3" Catback W/Borla XR-1, GM Built HD 4l60e w/ transgo shift kit, power servo and corvette shift pin, Yank 2600 Stall TC, Belltech 2/4 drop, Doetsch Shocks, 3.73 gears w/yukon lsd
4.8, 5.3 and 6.0 stock manifolds are the same. Corvette, F-body, GTO, and G8 headers will bolt up but not sure if they will fit in the engine bay
95 rcsb, built for the desert, sbc w/edelbrock mpfi, custom front long travel 18in travel, rear 4 link 29in travel.
94 ecsb, daily driver, 6inch rcd lift, 350 pending 6.0 swap, 14 bolt also on the way
 Member
						Member
						No it does not.
