Results 1 to 10 of 19
Thread: New MAF sensor
    Nov 2009
    Spring, TX
    Question New MAF sensor
    I was thinking of buying a new perfomance mass air sensor, what are some pros and cons about them?
    Jun 2010
    West Texas
    They really dont help at all. Most throw lean codes and cause problems later. Not worth it IMO.
    RUN WAT U BRUNG!!!!
    Pittsburgh, PA
    there isnt a thing called a performance MAF. A maf is a supporting sensor and when its time to upgrade its time to go SD. your stock 85mm is plenty
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Nov 2009
    Spring, TX
    Ok, o... by the way, what is SD?
    SD is Speed Density.
    Nov 2009
    Spring, TX
    Can you give more info lol
    Broken Bow, OK
    Nov 2009
    Spring, TX
    OMG... lol, like what is speed density, does it have to do with higher air flow?
    Dec 2008
    South Carolina
    hahahahahaha... speed density is when the pcm uses only the volumetric efficiency table to adjust injector pulse width. The VE table is basically a table of numbers that represent the pumping effeciency of the engine. SD uses the IAT, and MAP sensors and engine rpm to reference what value of the VE table to use to adjust fueling. Stock our trucks use a combination of the MAF and the VE table. It uses the VE table at low rpm/low air flow and switches over to the MAF at higher rpm/airflow since the MAF doest get stable readings with low airflow. People run SD to be able to copletely do away with the MAF so they can route the intake without having to worry about it and several other reasons. Some will say SD is better and some say using the MAF is better. I dont really know. I like the MAF myself because it measures actual dynamic airflow and is not a "guesstimation" like the VE table. That is why when you make a change to the airflow to or from the engine (ex. headers, cam, heads, intake etc.) you need to retune the the ve and maf tables in the pcm to decrease/add fuel to compensate for the increased/decreased pumping effeciency/airflow of the engine. Thats just my .02 and understanding of the subject. I might have missed a few things or be wrong on a thing or two but anyone is welcome to correct me
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    Nov 2009
    Spring, TX
    Quote Originally Posted by chvy=power View Post
    Thank you, so where would I get an SD... cause my MAF is messing up.
