Results 11 to 20 of 25
Thread: what pushrods for z06 cam
  1. #11
    May 2004
    <div class='quotetop'>QUOTE(motoxlifer &#064; Jan 23 2006, 08&#58;36 PM) [snapback]42010[/snapback]</div>
    Does anyone know why GM did this?
    All of the LSX cams prior to the LS6 had the same base circle radius. There was a problem with that base circle, if we wanted to go to higher lifts: the nose of the cam would approach the same diameter as the cam bearing journals or even above them. The only alternatives were to increase rocker arm ratio or reduce the base circle radius. GM decided to go with the base circle reduction. The ’01 base circle reduction did not require a change in dimensions of any other valve train part, however, the 405-horse cam was a different story. Because the position of the plunger within the hydraulic lifter is not optimal any more–you’re too high in the lifter. There’s different ways to correct the geometry. The one selected to minimize the impact on manufacturing operations was to increase the length of the valve. The valves in the 02 LS6 are 0.6-mm. longer than the valves in all other Gen III engines. With .025-in more intake lift, the same intake duration at .050-in but a little less duration at lash and the same rev limit; something had to be done to the rest of the valve train to keep it in control at high rpm. While the ’02 exhaust lobe doesn’t have quite the agressive profile as the intake, it’s still got more lift, so something had to be done there, too. The choices GM made were to decrease valve weight and increase valve spring pressure. With the higher lift, GM needed to reduce the mass of the valvetrain or start getting into a float condition. GM went to hollow stem intake and exhaust valves, very similar to what we used in the ’96 LT4. GM pushed the edge with a state-of-the-art, 0.8-mm. very thin stuff. The exhaust stems are sodium-potassium filled.
    BTW, most of this explanation is a quote by "Hicks" (GM).
    Hope this helps.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
  2. #12
    Jan 2006
    "All of the LSX cams prior to the LS6 had the same base circle radius. There was a problem with that base circle, if we wanted to go to higher lifts: the nose of the cam would approach the same diameter as the cam bearing journals or even above them."
    OK now I&#39;m now I&#39;m confused. If the original LS base circle won&#39;t allow larger lift cams without the lobes being bigger than the cam journals then how is, my cam for instance .600 int. & .578exh lift, and the stock cam had somewhere around .500 lift with the same base circle. The LS6 cam doesn&#39;t have .600" lift does it? I&#39;m just not understanding the need to reduce the base circle to get more lift when we can go out and buy aftermarket cams with way more lift than the LS6 cam and the same base circle as the original LS1 cam. Am I missing something?
    [1/8 mile E.T. - 8.23 @ 82.86 mph w/1.82 60&#39;] &#39;98swb,4/6drop,20"RozziDeeps on 275/40ToyoProxes &#39;98LS1/4L60E,TRCheaTR cam,Ported TB,Billet MAF ends,MSD8.5 superconductor wires,S&P midlengths,&#33;EGR,&#33;cats,2 1/2" true duals w/X-pipe,Dynomax Ultraflows,TCI 3000,billet servo,TCI deep aluminum pan,3.73&#39;s w/Auburn posi; Eclipse CD, Rockford 6 1/2&#39;s, Memphis 12&#39;s, Punch 200 ix, Punch 500x
  3. #13
    they reduced the small diameter on the cam lobe so that the highest lift point on the lobe will not be larger from the camshaft centerline than the bearing journals. If you were to take the high lift cam and roll it on the table, they didn&#39;t want the lobes to make contact with the table. If you kept the stock base circle and kept grinding taller lift lobes, it would get increasingly difficult to install the cams plus you you be pushing the lifter higher and higher out if it&#39;s bore. By reducing the base circle it gave them more room to increase lift.
  4. #14
    Jan 2006
    I understand the thinking behind it. What I don&#39;t understand is why you can go out and buy a cam with more lift than the LS6 cam but with the LS1 base circle and have no valvetrain geometry problems. The lobes on my cam aren&#39;t taller than the journals and it has quite a bit more lift than the LS6 cam.
  5. #15
    Hmmmmm, I thought Thunder Racing got their cams from Comp. I know they are ground on TR&#39;s specs. Maybe TR saw that with the final amount of lift they were specifying it wasn&#39;t high enough to change the base circle yet. I have seen guys running almost 1.000" lift on their drag racing only LS1s. If they didn&#39;t change the base circle on one of those they&#39;d definitely would either have to increase the cam bearing bore size or reduce the base circle just to install the cam. Those extreme lift engines most likely don&#39;t have the cam blank like ours that have a hole drilled all the way through it for lightening.
  6. #16
    Jan 2006
    Ya I can see a really huge cam needing a smaller base circle but the stuff we&#39;re runnin and the LS6 cam I don&#39;t understand the need. I&#39;m pretty sure my cam has the larger base circle, right? If not then TR owes me an explanation and some longer pushrods.
  7. #17
    Jun 2004
    pasadena, tx.
    ok im using the stock rockers off my 4.8 which should be 1.7 right? im also using 00/01 ls1 heads. so does that change anything? i was gonna buy some 7.4 moley ones that are a little thicker.
    04 4.8 FIPK, Pacesetter long tubes, dual exhaust with x-pipe and Dynomax race bullits, gutted cats, 160 therm, hypercrap programmer
    Future mods-p/p thottle body, 02 z06 cam, within the mth. 4:11 g80 soon after......just tryin to blow my tranny
  8. #18
    Is it possible to put LS1 heads on a 4.8? I thought the valves would interfere with the cylinders. If you plan on going higher lift of turning some serious RPM I would definitely suggest getting the hardened pushrods.
  9. #19
    Jan 2006
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Jan 29 2006, 08&#58;59 PM) [snapback]42651[/snapback]</div>
    Hmmm... have you ever heard of this happening? I&#39;m just curious,I don&#39;t know. I would have thought that all the LSX heads were basically the same other than port volume,comb. cham. vol. & valve size. Is that why the valves would interfere cuz they&#39;re bigger & the 4.8 bore is smaller. If so does that mean you can&#39;t put bigger valves in a 4.8?
  10. #20
    Jan 2006
    San Antonio
    You are going to loose compression if you do not mill the ls1 heads. Just somethng to keep in mind. You will go from 9.5 to almost 8.5
    Here are some basic numbers on the heads
    truck engine specs
    chamber 61.15cc
    comp. 9.5:1
    in port. 200cc
    ex port. 70cc
    in valve 1.89in
    ex valve 1.55in
    ls1 engine specs
    chamber 66.67cc
    comp. 10.1:1
    in port 200cc
    ex port 70cc
    in valve 2.00in
    ex valve 1.55in
    This is what gm says about z06 cams
    New for the 2002 Corvette, the 405hp camshaft for the LS6 engine option. Please note that this cam has approximately a 0.050" smaller base circle than a stock LS1 camshaft. This smaller base circle will require longer pushrods for applications with stock length valves and no milling for the head surface. It is imperative that you check your pushrod length when purchasing this cam. The 2002 Z06 cylinder heads use a longer valve to make-up this difference&#33;
    So from what I can tell it depends on the yr of the cam. I hope this helps some.
    Tattoos, Kustoms, Chops, Guns and Pits..........Need I say more? AFTERLIFE KUSTOMS.
    Getting ready to put an 82 Chevy 1/2 ton blazer under the knife.
    EL JEFE
    ROUGHNECK
