i did the plugs and wires about a year ago, i will try the filter. my father is very against putting any more money into this yukon, but i will try. thanks again.
on a 2003 Yukon it has the same fuel filter as the trucks....UNLESS it is Flex Fuel, then it has the quick connect fittings.
- Paul J.
2006 Silverado LT3 L33 Z71 - Mods: K&N Air Filter; Taylor Wires
2008 Azera Limited - Mods: (Yah, wife's car ... not happening)
(SOLD) 1994 Camaro Z28 - Mods: (Too many to mention)
(SOLD) 2004 Suburban 5.3L Z71 - Mods: Flex-a-Lite 292 Monster Fan
(SOLD) 2000 Silverado 5.3L Z71 - Mods: (NTIKO)
(SOLD) 1991 Suburban 350 2WD - Mods: (NTIKO)
 WTH JUST HAPPENED?
						WTH JUST HAPPENED?
						Reduce weivht as much as possible. Install a vacuum gauge and keep it as high as possible while driving..
i will pull out the extra seats, and replace fuel filter, how many o2 sensors does the car have, and how many do i need to replace. thanks agian.
The ones they are refering to for fuel mileage are the front two. So you need two of them. They can be called upstream sensors, becuase they are upstream of the cat converters. There is one for each side of the engine and they are the two that are closest to the front bumper.
To answer the rest of the question the truck has four of them. The other two do not effect the fuel trim, they are there to monitor the cat converters and tell the pcm they are there and doing their job. Have you noticed a lack of power? If not then I doubt the cats are causing your lack of mpg. If you are getting gas with more ethanol it will reduce mpgs too.
99 silverado 2500 4x4 ec lb, lq4 with 243 heads, pace setter long tubes, true duals with x pipe and bullet mufflers, comp 222 224 112 cam, 8.1 truck injectors, 4l80e with 2800 stall, 373 gears, 285 75 16 tires, efi live tune in progress, 350rwhp 360tq, 11.8 average mpg mixed driving
