Results 1 to 8 of 8
Thread: No forward or reverse gears help!
    May 2006
    Waco TX
    Well just got the new motor put in about 2 weeks ago, and no the truck wont move. I've been driving the truck easy the whole time, then sat morning going about 40 mph when the tranny went out of gear.
    Now my first thought would be maybe the front pump. So I checked the tranny fluid in park. Put it in drive and checked it again. The fluid dropped quite a bit on the dipstick tube when put in drive. So that would make me think the front pump is working.
    Anyone have any Ideas? I havent gotten around to taking the tranny out, don't feel like messing with it. Maybe it could be something simple, or bad torque converter is bad.
    Transfer case issue?
    Racoon Twp., PA
    No boom? Just went out of gear?
    No noises when in gear?
    Good call Red.
    2013 CC 5.3
    81 C10 LS1 project
    May 2006
    Waco TX
    Nope. It didn't make a sound. It sound normal at Idle also. How would I check the transfer case?
    Racoon Twp., PA
    AWD I assume.
    Even if the chain (or gears) would break the rear shaft would still turn. So, i would drop the shafts, keep teh tranny in Park (hoping that still works) and spin the rear output shaft on the tcase. If it spins freely then internal breakage on it. If it doesn't turn due to the truck in park, then it is in the tranny.
    2013 CC 5.3
    81 C10 LS1 project
    Same transmission problem happened to me little over a week ago, It was my pump. Try checking the ATF level with the truck not running, mark it on the dip stick then start the truck and check the level again. You can do that or check the port on the side of it for psi output. My moneys on the pump but may be just maybe the filter dislodged its self from the pump inlet and the pump isn’t getting any ATF due to lack of vacuum.
    May 2006
    Waco TX
    The pump doesn't activate in park right? I checked it in Park. Then put it in drive and the fluid did drop quite a bit on the dipstick. My first assumption was the front pump since no gears, but this makes me think the pump is working.
    I’m 99.99% sure the pump works in park due to the fact that the TC drives the pump and the flex plate drives the TC
    also was thinking, how old is the TC?
