Page 4 of 7 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 31 to 40 of 62
Thread: Master cylinder for a T56?
  1. #31
    May 2010
    Hillsboro, OR
    Haven't put the headers on yet. I'll let you know. They say they only support a specific mounting plate. I believe it does move the engine 1" forward. I haven't decided yet for sure on the shifter. If I go the McLeod route, I'll let you know. I know what you mean about getting the parts list together.
  2. #32
    Oct 2008
    Tennessee
    Did the T56 mount in same place as 5sp? Did you do your own harness? I have a DBW(from 05) and DBC but am not sure which one to use. I do not know if all the DBW will work with any PCM.
  3. #33
    Haha, yeah I think GM also put the 4L80E behind some 4.3s in vans and stuff, kinda unexpected.
  4. #34
    May 2010
    Hillsboro, OR
    Quote Originally Posted by Old Nash View Post
    The crossmember was used, but had to be relocated in the frame a few inches. The 5.7 LS1 came with a harness, but it was pretty ugly. I have a Nelson harness and programmed ECM.
  5. #35
    Oct 2008
    Tennessee
    I measured my drive shaft and it was 61". I found out the 14 bolt also uses a different U joint(1350) and 10 bolt uses a 1310. I understand you can buy a u joint with the two combined to hook the drive shaft to Rear end.
  6. #36
    Well it took me a while to find my camera but here is a pic of the stock shifter location for comparison to one that has been relocated.
  7. #37
    May 2010
    Hillsboro, OR
    What seats did you use there?
  8. #38
    '97 Tahoe bucket seats.
  9. #39
    Oct 2008
    Tennessee
    I bet you found the camera in the shoe. lol
    Thanks, the picture gives an ideal how far it is back between seats and how McLeod shifter would help. I found a picture of what a guy did to incorporate his 6 sp shifter into the console.
    www.akvalley.net/~ss/
  10. #40
    I just know you don't want to hear this but here is the clutch master cylinder of the month....http://www.tick-performance.com/tick...dy/hydraulics/
    Homepage http://www.tick-performance.com/tickshift/
