Results 1 to 10 of 10
Thread: LS6 Heads
    May 2004
    I just bought a brand new set of these (88958622) and was wondering if anyone makes a head gasket to lower the compression ratio? I'm also running a .581 lift cam and know there's gonna be an issue there. This is the reason for the thicker gasket. I've got a brand new set of hardened pushrods and springs in the 241 heads I have now. I'll probably sell the LS6 springs and the hardened pushrods once I get the right combo together and post them here. Give me some feedback. Thanks
    Complete Cylinder Head with springs and valves.
    Combustion chamber volume 60-61cc
    Intake runner volume 250cc
    Exhaust runner volume 85cc
    Intake valve diameter 2.00"
    Exhaust valve diameter 1.55"
    Intake valves are lightweight hollow stem design
    Exhaust valves are sodium filled for improved cooling
    .055" machined from deck surface of head-Intake pilot pin bosses will need chamfered, and 7.325" pushrods should be utilized.
    CNC Port work done by Lingenfelter
    Special LS6 valve springs good for .570" lift
    Will increase compression ration to 11.2:1
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    Damn, that's a nice head. Sounds like time for octane booster. Can two MultiLayerSteel(MLS) head gaskets be stacked? Being steel it shouldn't be an issue, should it?
    Jun 2004
    pasadena, tx.
    well when ur done with the old zo6 springs let me know i need a set
    04 4.8 FIPK, Pacesetter long tubes, dual exhaust with x-pipe and Dynomax race bullits, gutted cats, 160 therm, hypercrap programmer
    Future mods-p/p thottle body, 02 z06 cam, within the mth. 4:11 g80 soon after......just tryin to blow my tranny
    Jan 2005
    Conway, AR
    If you get rid of the pushrods I got dibs!!
    Chris
    Jan 2005
    Conway, AR
    btw, how long are those pushrods, I am looking for 7.45" to make up for the smaller base circle of the Z06 cam.
    Chris
    Feb 2005
    Doesn't Cosmetic make thinner head gaskets?
    New Truck on it's way: '07 Classic GMC 2500HD DuraMax LBZ
    03' Silverado ECSB 4x4 Z71 LQ9, TR230, Patriot LS6, 31lbs, Trailblazer stall, Corvette servo, Corsa Touring,
    HP Tuners
    SOLD - 99' Silverado ECSB 4x4 5.3, Edelbrock RPM, Nitto Terra Grapplers, Texas-Speed Tuned 02' PCM, LT1 fans
    May 2004
    RHB - Steel head gaskets stacked, not sure bro but it's something I'm gonna consider.
    djkir23 - I'll post them here on the forum as soon as I make the swap.
    chrisj6 - They are hardened 7.4 MTI pushrods. I remember you wanted some 7.45's in the LS6 cam post. I'll still post them when I'm through with the swap just incase you or someone else is interested.
    Zick - If they make thinner, maybe they make thicker. I'll look into them.
    I'm really worried about the valve to piston clearance with the .581 lift after some reading. I'll probably use some modeling clay on top of the piston to take the clearance since it doesn't spring. Bare with me on the springs and pushrods guys, I don't want to tear these heads apart without all the info I need.
    97 GMC, 2002 LS6.
    May 2004
    MLS (multiy layered steel)by Cometic
    Compressed thickness from .027" to .051" - $172.00 pair
    Compressed thickness of .060" & .065" - $200.00 pair
    Compressed thickness of .071" & .074" - $216.00 pair
    Compressed thickness of .120" - $370.00 pair
    Looks like there is some better deals on ebay and Mr Gasket sells these type gaskets also.
    Thanks guys
    97 GMC, 2002 LS6.
    Post over on LS1Tech's wanted page for the MLS gaskets. I got a pair for my old truck for $60 shipped over there.
    May 2004
    That's a damn good price! As soon as I find out how much valve clearance I need I'll do it. Thanks RHB
    97 GMC, 2002 LS6.
