Thread: Stock fuel lines
    Hey Guys, maybe someone has run into this.
    Does anyone know where to get stock type gm fuel lines made?
    I'm talking about the ends that go on the fuel rails, that type of connector.
    I was to get some fuel line made that has the stock GM type connector on the end of it so I can just slip them on. I have other way of connecting them, this is for another truck I'm workinig on and it'll work out better instead of using compression fittings.
    thanks in advance,
    allen
    Dorman makes the 5/16 and 3/8 replacement ends that slip on the standard connection. Orielly is where I get mine just over $10 each. You can buy a crimping tool to crimp air compressor fitting ends to make a nice crimp over a 3/8 fuel hose.
    The guys that build hydraulic lines for tractors have a nice crimp sleeve and tool to crimp with. NAPA builds them locally in Denton. I'm sure you have an implement dealer or NAPA somewhere around you too.
