Before I replaced my drivers side lower ball joint my steering wheel was straight as an arrow. Now, my steering wheel is cocked to the left. It doesn't pull, but it kinda annoying. Do I need an allignment after replacing it?
yeah go ahead and get it straightened out at an alignment shop
Did you replace the lower ball joint?
If you can replace a ball joint you should try the alignment yourself, Ive been doing it for years and always works out great, Only time I pay for one is when its the camber or caster that needs adjusting.
Yeah, I had someone put it on for me, so I'll just take it in. The local place here in town only charges $60. Thanks for the info.
your tierod got adjusted somehow. that's why the steering wheel is off.
11' Sierra 6.2 NHT
14.46@91 Stock
89' Mustang LSX
10.35@130 pump gas LQ4
Knothead Racing
I wonder how it got adjusted. Do you have to remove it to do the ball joint?
no but if the ball joint was out it was sloppy and now its tight so things are at a little different angle.
Gotcha. Yeah, the boot had been torn for a while and would pop and creak when it got dry. So it was pretty much shot.
