i have a ton of stuff that needs to go! anything you see is for sale even if i forget to list it. make me an offer on anything all the little stuff should be $5 and maybe the bigger stuff up to $20 etc just help me GET IT GONE
buyer pays shipping
OBS water pump with clutch fan
AC radiator with lines
AC lines
NBS upper radiator hose NEW
5' unshaped upper radiator hose NEW
OBS headlights
OBS starter
OBS intake gaskets fel-pro NEW
OBS distributor
OBS coil
NBS battery/alt connect box and bracket
OBS tcase skid plate
OBS mud flaps GMC
OBS serpentine belt AC/Power Steering
Drivers light is new, passenger is OEM needs polising
OBS marker lights
OBS intake box and NEW filter
OBS intake and flex hose
OBS MAF
OBS tranny inspection plate
OBS valve covers painted black/red
OBS EGR hose NEW
OBS factory CD player + deck
OBS plug wires, air intake scoop
OBS block heater wire (goes to special freeze plug)
OBS AC compressor
NBS AC compressor
NBS AC mount, idler, belt and tensioner
OBS belt tensioner and bracket
MISC BRACKETS + HOSES
OBS AC canister
CHEVY alternator (needs to be unfrozen)
NBS engine mounts
Alternator to Battery wire
OBS fuel rails
OBS emissions valves
Ground Strap
OBS tranny locator bars
NBS 2001 6.0 4.80e flywheel and spacer - possible use for LS conversion?
OBS external tranny cooler and bracket
NBS emissions hose
OBS horn (middle)
OBS Vortec 5.7 - ran when removed needs a rebuild or makes for good spare parts
OBS torque converter
NOT PICTURED
NBS stock 6.0 injectors
OOBS rancho steering stabilizers DUAL NEW
