so youre saying sounds like a cat ?wouldnt it run better if the cats were blown out rather than clogged?does this hve 2 cats or just one on the original exhaust?its stock ,i really havent looked at them.yes its stock so it has the original converter 160k on it.should i just cut it off and see,or would i be better off pulling the manifolds off the block to see?
