Results 1 to 10 of 14
Thread: Dual fuel pump?
    broke1 Guest
    Dual fuel pump?
    I have searched on here after seeeing a dual fuel pump mentioned for these trucks.Does anyone know where to get them from?
    Or is the Magnacharger kit plenty?Anyone have a part # for that kit?Tried searching here and online with no success....
    Oh,truck is an 05 Escalade EXT with the 6.0/4l65 that will have LT's,exhaust,CAI,160 stat,ported tb,and tune.One day it will get heads/cam/intake and when the engine goes it will get a stroker....Probably never have a turbo or supercharger.Id like to only buy once....
    Thanks for the info!
    The Garage
    You'd only need a dual fuel pump setup if you're gonna go with about 500+ to the wheels. Anything under that, you'd be fine with a walbro 255lph and injectors sized to your needs.
    ff_jeff Guest
    Quote Originally Posted by jetmech View Post
    Yeah, I doubt youll hit that much power. But, Check with the site vendors first, then check Ebay. I got 2 High psi walbros for $199 shipped.
    broke1 Guest
    I will not buy another Walbro because of dependability issues...I like the TT Supra Denso pump and it flows more than the Walbro.
    I would rather have somthing that just drops in without hacking though.Buy and buy once is my motto...
    Thanks for the info though guys!!!
    Anyone know where to get these dual fuel pump setups?
    ff_jeff Guest
    you can make them. There is a guy who sells a kit, but I dont remember his name.
    Quote Originally Posted by broke1 View Post
    You must have gotten a few bad knock-offs. Damn Chinese are flooding the market with copies complete with the Walbro symbol stamped on them. One clue I hear is that some of the knock-offs don't have a polished case like the legit units. I've never had a Walbro failure. I always get mine from Racetronix. NelsonPerformance sells genuine Walbro pumps, also.
    BTW, a bosch 044 pump is awesome, too, and pumps out some great volume numbers.
    search the web, here's what I found in a matter of seconds.... Efini Dual Fuel Pump Setup
    Spring, Texas
    +1 on the Walbro. Been running mine for over 2 years with no issues and didn't have to hack the bucket at all. To each his own....
    broke1 Guest
    Ive owned Grand Nationals for years and I am well aware I can build my own,I want to buy drop in if I can though....
    And as far as getting knock offs,the last bad pump I bought was from Racetronix and was bad out of the box.Jacks reply was "no warranty on pumps"Adding insult to injury,Jack still owes me parts that were not included in his kit making the $100+ I spent a total waste...his wiring solutions are top notch(have everything he offers for the Buicks on both my GN's),however,I would not reccomend Racetronix products as Jack will not stand behind them at all...Have an issue and u are on your own or it will be blamed on installer error.
    044 Pump is great but Denso flows more...do a search and u will see!!
    If anyone can remember the person who sells the dual pump setup for the LS based trucks,I would greatly appreciate it!!Thanks!
    here's a company the can build you a system... Lonnies Performance Automotive ---- Main Index go to their section Fuel Systems and then Double Pump Kits.
