Here is what I did to install the AC compressor on my gen III engine. I grabbed a 88-92 camaro AC compressor bracket to start and hacked the unnecessary parts (AIR pump mounting) off of that using a grinder and cutoff wheel. I then cut off the mounting points so the pulley sat the correct distance from the block. Next I built some supports using 1/4" steel barstock. They attach to tapped holes in the head and the water pump tensioner mount point.
For the tensioner I flipped the truck tensioner 180 degrees. This requires it to be mounted with only 2 bolts like the corvette tensioners are. You also must clearance the back of the tensioner with the trusty cutoff wheel and mill one of the bolt holes for the water pump to block bolts down a little bit to provide clearance. Since the truck pulley has ribs on it and with this setup the smooth side of the belt will be touching the tensioner, I used the tensioner pulley from the 88 bracket along with a small spacer to make it fit.
Amazingly I did all this with hand tools and no mill or lathe. I did use a welder to attach some washers to one of the brackets, but that wasn't truly necessary, just makes service easier in the future.
BTW, using the TPI camaro bracket was not my idea, I got it from someone else on this board.
Pics:
