oh so tempting... because i know mines barely leaking and etc... ill let you know mang. itll be a lil bit and being that your in austin even better...
02 Chevy EcSb Z71, 5.3, Helix Tb Spacer, AEM Brute Froce Intake, Msd 8.5 wires, NGKTR55 IX, B&M 25k Trans Cooler, Hypertech 160, Nelson Tune, Nelson Harness & Ls1 fans, Fully Built tranny, tb2600, 216/224 551/551 115LSA, yeller z06 springs, magnaflow, cut-out, hi-flow cats, etc...
Bump for a good deal. The only two common leaks are the rear seal (easy and obvious) and the pump clip that wears through the case. Get this one while you can.
I going to try to get a dyno tune at nelson in about a month. I could bring the case with me. PM if interested.
5.3, E-fans, LPP longtubes w/offroad Y, Dual Magnaflow, K&N Cold Air, 160 thermo, Voodoo 212/218 .531/.531 113 cam, Nelson Tune, 4:11, Built 4L65E, TrailBlazer converter. SOLD
_____________________________________
2006 2500HD 6.0L Crew Cab 2WD
hey man, since you went 2 wd, do you have the 4x4 cluster, i need one for my 01 Z i have a 2wd cluster but like i said i need the 4x4 as soon as i get the cluster i can engage the 4x4 and if it doesnt work i might need the transfer case![]()
What is the difference in the cluster 2WD to 4WD?
