Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: Trailblazer Stall Worth Putting In?
  1. #11
    naples fl
    if that's all you can afford then its worth it.
    01 GMC sclb d-max 2wd.
    2.2 60' 8.9 1/8th
  2. #12
    Spring, Texas
    Here's a fresh Yank if your interested:
    Fs=== yank converter - PerformanceTrucks.net Forums
  3. #13
    southside VA
    i think a tb converter would def. be worth it,if u could get one cheap
  4. #14
    wichita falls, tx
    me and Nathan are putting one in my truck this coming weekend, ill let u know if it was worth it...i got mine for 125 (which is super cheap compared to and aftermarket verter), but ill post up the differences between the stock truck verter and the I6 tb verter after i do the swap
    Intro Radicalli's
  5. #15
    Quote Originally Posted by banker099 View Post
    COOL KEEP ME UPDATED
  6. #16
    The TB stall is about a 2300-2400 stall. If it is cheap, why not? It would be a good stall for your Maggie truck. Maggies don;t need but a few RPMs off idle to start making good power...
