Page 15 of 28 FirstFirst ... 5 13 14 15 16 17 25 ... LastLast
Results 141 to 150 of 273
Thread: Lost 3-4 clutch pack...exploring options...
  1. #141
    Very much so. Does it shift good 1-3 right now?
  2. #142
    Mar 2006
    Mesquite
    yes...it shifts good, I get just a little bit of slip if it's under much of a load. And the slightest shudder around 1500 rpms.
    What does the vac bypass and all do?
  3. #143
    that could be the converter then if you're getting shudder.
  4. #144
    The vacuum mod kit uses engine vacuum to control shift pressures rather than the tune and pcm controlling it. It's going old-school to manage shift pressures. The bypass is so that boost does not affect the shift pressures. If a sensor goes bad, the PCM will send bad shift pressure control to the trans and you can burn it up or break parts with too harsh of shifts. A bad TPS or coolant sensor will trigger the PCM into "safe" shift modes that bang gears really hard and can break or damage the internal parts of the trans.
  6. #146
    Mar 2006
    Mesquite
    Well now I can't tell if it's exhaust resonating or what. It's barely noticeable. I think I'm looking for stuff to be wrong, so maybe it's nothing.
  7. #147
    Nov 2006
    Mesquite, TX
    come by and grab me one day and i will go for a ride with you and see what i think maybe?
  8. #148
    Mar 2006
    Mesquite
    Yeah - will do.
  9. #149
    Mar 2006
    Mesquite
    OK ordered both of those and a new PATC 10XXX harness. Here's hoping...
  10. #150
    Another project for the weekend, huh. At least its an easy install, only a couple hours to do.
