05 Crew Cab....just starting the mods!
5.3 w/ Airraid intake tube, stock box with K&N, MBRP 3.5" cat back, Dynatech Longtubes, wait4me tune....to come...4.10's, custom Dyno Tune, maybe a few other goodies.
I'm going to put a hybrid sticker above or below my 6.7L stickers when I do them.
thanks fellas.
John
Four by Four to the floor.
they work fine on a 4x4.mine were easy to install,i did do them on a lift tho.yes youlle gain some performance ,it was 1 of my favorite mods.
" I wonder how far off the Pace setter off road y would be? Then i can install some high flow cats "
Can't help you on that old buddy, need some PS people to chime in.
time for some more![]()
