Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: fuel pump
  1. #11
    Oct 2005
    its very similar to the stock pump.
    X2, easy to install after you get the old one out
    '92 Fullsize, swb rc
    5.3L/T56 conversion, comp XR275 HR cam .566/.568 lift 222/224 duration 112 lsa, crane dual springs, trick flow push rods, K&N Filter, Nelson Performance tune, Keisler shifter relocation kit, Boyd Coddington Smoothie II 18x8 235/55 up front, 18x10 295/45 out back, 2/4 drop, eaton lsd w/4.56 gears
  2. #12
    phoenix az
    on my 98 i put in the walbro 255 and have had 2 go out in 4 months. im giving up on them and putting in a stock unit. but maybe i just have been having bad luck lately
    1998 chevy 1500 with 6.0/4l80e comp cam, tune, exhaust,
  3. #13
    Maybe they're sending you the cheap knock-offs.
  4. #14
    phoenix az
    its a possibilty they r from bbk. who knows i give up though lol
  5. #15
    Buy one from Racetronix.com along with a hotwire kit. You may not be running a large enough power wire and its burning them up because of it, that or you're just running the tank on empty all the time and they're getting too hot.
  6. #16
    phoenix az
    im wondering if thats whats going on. but last night on my back from vegas it started acting up and almost left me stranded. i just order up a new stock pump and going to put it in and see what happens
  7. #17
    walbro has a bad batch of the 255, i think mine is bad too, takes a few cranks to start.
  8. #18
    lets say the 96 fuel pump will work, is there an adapter to adapt the stock (96) line to the 03 fuel rail (different fittings)?
  9. #19
    phoenix az
    yeah russel makes some. my 255 would lose pressure and would only make 10 psi but like red said i think its not getting enough current through the stock wiring
