 Member
						Member
						Pete
2002 Chevrolet Silverado
2002 Pontiac Trans Am WS.6
2004 Dodge Ram CCSB Cummins Turbo Diesel
1989 Chevrolet Silverado RCSB - Work Truck, Vortec 454 swap in progress :rocking:
1972 Toyota FJ-40
1963 Chevrolet Corvette Prostreet
The cluster doesn't matter because I've tried 96-2000 and they all work the same. ChevyLee, did you say you pulled the switch off and turned it by hand with it plugged in? Did you leave the NS switch connected to the old harness or is it all in the new harness? Sorry for all of the questions but this is driving me crazy!!
97 GMC, 2002 LS6.
1991 GMC Syclone #1428
Its also driving me crazy. It is connected to the new harness. i pulled it out, left it plugged in used my ratchet to turn it *it just so happen to fit in the hole*. I turned it and watched the orange light move, it would go P R then it would shut off, then come back on in 3 and 2 then shut off. I put it back on while it said it was in R but it was really in P. Moved it a few times and shut it off, then turned it back on and it went back to Phair pulling
 Member
						Member
						Pete
1972 Toyota FJ-40
1940-94 Chevy/ GMC Trucks
wish they made one for the 98
Ya, that sucks! I wanted to buy a set for my truck a few years back and they said they probably wouldn't produce them.
97 GMC, 2002 LS6.
This is the info I got from worley.1
I spoke to Jerod at Current Performance and he told me to take the Purple/white and Yellow/white wires from the factory harness going to the VSS and hook them up to the wires going to the VSS coming from the 4L60E which are Purple/white and Green/white on the harness that I have from Current Performance. he said that I need to scotchlock them. Purple/white to Yellow/white and Purple/White to Green/white. I know seems backwards. I will try it and let you know if it works.
He tried this and it works.
I tried this on my 4l80E and the speedo works! Im so happy!!
89' GMC RCSB 6.0L LQ4, T56, 4.56 Gears
 Member
						Member
						Pete
1972 Toyota FJ-40
