Page 3 of 3 FirstFirst 1 2 3
Results 21 to 26 of 26
Thread: Conversion pics
  1. #21
    Hurley, Mississippi
    Great pics for someone starting a conversion or someone trying to clean up one they already started. Do you have part #'s for the tranny fittings? Those OEM quick disconnects are leaking on mine.
    '86 Silvy- '06 6.0/4L80E, K&N, 2.5 X-pipe Magnaflows, 20" Foose Wheels, Auburn Pro, 3.90 Richmond Gears, and the list is growing!!!
  2. #22
    so this is probably a pretty newb wiring question BUT....
    in the pics, there are 5-6 wires going to terminals on the passenger side firewall, looks to be right where the old OBS underhood relay/fuse panel/whatever was, they are just studs sticking out of the firewall (sorry for my terminology).
    what are these? grounds? are they connected through the firewall to fuses/relays? just trying to get an idea of whats going on there.
    thanks
  3. #23
    That is a power distribution block. One main power lead comes to it and then supplies a large number of other places with 12V power.
  4. #24
    got it, so its not a bunch of grounds, its a bunch of +12v terminals tied directly to the + terminal on the battery?
    is that pretty standard way to do the wiring for the swap too? it looks pretty clean that way.
  5. #25
    Quote Originally Posted by Norcalz71 View Post
    It's a factory block, we just used the block to tie his stereo system and other stuff to power. It's a handy device.
    When doing grounds, be sure every major component is grounded. Tie the chassis to the block, the block to the chassis (at 2 pts), the block or chassis to the battery, and the battery to the fenders. You can't have enough grounds.
  6. #26
    SOMO
    Looks good, can't wait to get mine going
