Results 1 to 10 of 18
Thread: 240sx hotness
    Feb 2008
    Vermont
    240sx hotness
    Hey guys and gals, I just finished wet sanding and buffing my 240 tonight, so here's some pics.
    In case your wondering what this has to do with ls1truck.com, I'm putting a 2003 5.3l in this 240 in about another month or so and I've found a ton of useful information on here.
    The paint is a DBC quality, sprayed right here in my shop, all work done in house. Removed the stupid factory wing, filled the holes or smoothed/shaved the holes, painted the factory wheels that came on it because the aftermarket 15's i bought the car with were missing the center caps. The paint is called Blue Black Mica and is out of our PPG 2002 Foreign Paint Book, in the Subaru section; if anyone is wondering.
    Anyway:
    There's no replacement for displacement.
    niceeee. how far are you on the 5.3 work?
    Dec 2003
    Azle,TX
    Sweet car....
    Vortec Performance Tuned
    Feb 2008
    Vermont
    As far as the 5.3 swap goes, I still need: DBW pedal assembly and harness, Koyo KA (nissan "jdm" radiator), Dakota Digital Speed box, 2wd 4l60e driveshaft/yoke (is the 4l60e camaro driveshat yoke the same as the 2wd truck one?), and a MAF sensor. I also need headers (found some on summitracing that will work), some mufflers, and a bunch of other little things.
    But it's going pretty good, I got my camaro accessories from KruznLow. I could start removing the stock engine and start fitting the 5.3 so when i get everything i just bolt it on and go, but I want to drive the car the way it is for a while to get used to it.
    Thanks for the comments
    Jun 2007
    i wonder were ya got the paint for the tires ?it looks like tire shine.do they have it in different colors so you can match or contrast youre paint job?j/k looks good.
    Feb 2008
    Vermont
    lol, the tires i just used some good armor all like stuff we get from APP (auto paint plus). But the wheels I am going to redo with some left of the left over blue black mica and some good clear, instead of all rattle can crap. i was bored when i did them.
    Oct 2007
    connecticut
    paint looks real nice i know where u can find some 4l60e parts
    02' silverado ext. cb 2wd , 5.3 liter 325c.i. LM7, ported and polished throttlebody with bypass, Jannetty Racing 87 octane dyno tune, cold air intake with custom ram air, Heavy duty built 4l60e with vette servo, Z-pac clutches, "The Beast" Sunshell, transgo shift kit, yukon 4.10 gears with true trac, custom exhaust with Moroso Spiralflow, no cats, MSD 8.5 race wires, NGK TR55's
    Damn dude, take it easy on yourself during personal wacky time lol.
    Sometimes it can get out of hand
    Satan just called - hell froze over.
    I take it like a virgin on prom night... I'm not happy, it hurts, but at the same time, I'm too drunk to care.
    Feb 2008
    Vermont
    lol, yeah. But your not getting rid of your drive shaft/yoke are you? If you are I'd be interested...
    Jan 2006
    I have a buddy in our local group doing an LS1 in a 240 right now.
    12 Sec. Club! SOLD
    SOLD***
    ff_jeff Guest
    I love the idea. You might want to buy a cam, and possibly anything else major before you put the motor in... Make install allot quicker. and save allot of busted knuckles and sore back muscles.
