I've searched over 100 threads, couldn't quite get the answer.
05 GM factory Efans & harness(got it with the fans), 00 silvy pcm programmed by Nelson.
I already have green wire to pin #42 on the blue plug, and was sure that the light blue wire went in pin #33 on the red pcm plug(green on 05 pcm). There is already a dark green wire into that pin, and I just need to know what to do with my blue wire.
I'm just worried because I read that the 00 pcm's use different pins but I don't think they do. Do I tap into the existing wire, or ground the blue wire, and I have the right pin, correct?, etc, etc.
TIA.
