Results 1 to 10 of 11
Thread: Manual Tow Mirrors to Power fold/heated NO power to any controls
    Feb 2005
    Austin, Texas
    My truck came with the totally manual towing mirrors and I recently purchased some power fold/heat/turn signal mirrors to swap on. Everything went fine swapping the pass side, I went to test it and nothing worked so I figured the driverside had to be done before it would swapped it on and nothing worked. My windows and door locks dont work either on the front two doors. The rears work when I start the truck and put it in drive it tries to lock all four doors but only the rear two lock. The driverside turn signal works in the mirror but not the passenger side turn signal in the mirror. Am I missing something? I could understand if the plug was loose or something but not on both sides. Does it need to be flashed by the dealer, I already called the service department and the service advisor I got ahold of had never heard of it which doesnt surprise me. The truck is a fully loaded LT leather etc. keyless entry doesnt work and dome light doesnt come on when I open the door. Does the BCM need to be reflashed? From my reading it sounds like thats what needs to be done. The dealer wants 100 bucks to do it.
    Was it a pretty straight forward wiring schematic?
    Yes Cody...the BCM needs to be flashed by the dealer.
    did you check the fuse, i think on the 4 doors they have separate fuses, that happend on my truck pass door worked fine but the drivers side wouldnt do anything and it was just a blown fuse.
    Feb 2005
    Austin, Texas
    No schematic to it, just take the two plugs off the mirror and plug it into the bottom of the window/door lock panel, and repeat for the other side. Rear windows and locks work just not the front ones. Damn dealer wants a 100 bucks to do it, this mirror swap thing has gotten expensive.
    Feb 2005
    Austin, Texas
    Dealer flashed the PDM and all is well now, I love my new mirrors, soooo much better then those old POS's. Will be time for Daniel to do his thing soon, then get a real trans in this thing and load up a 500+rwhp/1000+ ft-lb tune
    well damn now we know how to do ours.. glad it all worked out for you.
    Oct 2007
    connecticut
    wait, i can have mirrors with heat and turn signals without having to pull teeth and spend a fortune?
    02' silverado ext. cb 2wd , 5.3 liter 325c.i. LM7, ported and polished throttlebody with bypass, Jannetty Racing 87 octane dyno tune, cold air intake with custom ram air, Heavy duty built 4l60e with vette servo, Z-pac clutches, "The Beast" Sunshell, transgo shift kit, yukon 4.10 gears with true trac, custom exhaust with Moroso Spiralflow, no cats, MSD 8.5 race wires, NGK TR55's
    Damn dude, take it easy on yourself during personal wacky time lol.
    Sometimes it can get out of hand
    Satan just called - hell froze over.
    I take it like a virgin on prom night... I'm not happy, it hurts, but at the same time, I'm too drunk to care.
    Davids (both of you), it is not that easy my friends!!! Us (99-02) guys are kinda up chit creek when it comes to Powerfold or signal mirrors. You can get powerfold mirrors if you want, but it will cost ya. the signal mirrors are not as bad...we can tie the mirror to the blinker circuit quite easily, but it involves cutting into the wiring harness, which I HATE doing... The 03 and newer trucks can go have the BCM flashed and viola! We can't...
    I would just rather have the ones that have th eturn light on there anyway. I can just stick my hand out and fold it myself
