Results 1 to 9 of 9
Thread: How to install 2" drop rear shackels?
    Austin, TX
    Hey everyone,
    I want to level out my truck w/ 2" lowering shackels for the rear. I've seen they run about $50 and most shops will install them for about another $50 as well.
    Can anyone list out the basic procedure and tools required for installing 2" lowering shackels for the rear?
    I'm just trying to figure out if it is worth messing with or just pay the extra $50 to have the shop do it.
    Thx!
    2000 RCSB 1500 2WD - Stock 5.3L - 18 x 8 Centerline Rims
    S.A. Texas
    takes no time. all you need is jack, jack stands and wrenches, but an impact makes it easier. might take you an hour and a half
    wichita falls, tx
    yeah...2 bolts on each side....and should take bout 45min-1hr for a first timer....save $50 and do it yourself!
    Intro Radicalli's
    Dec 2003
    Azle,TX
    If you have a sportside truck...add another hour to that time to bend the bed out of the way!
    Vortec Performance Tuned
    Do a little searching and you'll find a post or two about doing the shackle conversion. I think two were written in a months time, one I did and I can't remember who wrote the other one. Its a very easy job but you'll need a jack and stands, 22mm wrench and socket.
    Quote Originally Posted by 2Kchevy View Post
    Hey everyone,
    Thx!
    I did mine in 30 mins flat with out air tools.
    Got to be one of the easiest suspension mods ever.
    Barney- 89 S-10 Blazer, 355 11:1 small solid roller and a lil' gas.
    http://youtube.com/watch?v=DdxAzQjNuGU
    96 Formula- Just some bolt on suspension stuff...LT1 350 a4
    06 GMC PU........4.8 and stcok....may get a few things thrown at it.
    Austin, TX
    Thanks for the advice.
    I'll do some searching on the steps I need to take.
    Sounds like I've got all the tools for the job.
    Thx.
    Its a little harder if you have a hitch gotta take it off or cut it but it is very easy to do
    Slimsilverado Guest
    Yea u just need some big wrenches and thats it
    maybe a friend to help wrestle the spring back into the bucket once the shackle is on..
