Can anyone tell me what the following block casting number is from: 12561358?
I just found out my heads are 862s and those are from 4.8L. I'm nervous my block is also from a 4.8L. Thanks in advance!!
is it an aluminum or cast iron block? 4.8/5.3 are cast -5.7 aluminum
4.8 and 5.3 blocks are the same the only thing diffrent is the crank. I think there the same heads too
old set up: 2002 chevy 5.3, procharger 12lbs boost, asm headers, ls1 edit, flames, 20inch budniks
New Set up: 2004 chevy 5.3 ext cab, 12 inch twisted suspension lift, 36's, exhaust.
future mods: 150-200 shot, ls1 edit, air intake, stall, 5.13 gears, 12s or bust
This is a cast block. Then without opening up the engine, I won't know what I have...
So the 4.8 and 5.3 use the same heads and block. The 6.0 uses the same crank as a 5.3?
I think so i know that the 5.7 use the same crank. im almost sure they use the same crank just the bore size is diffrent
