Thread: Valve spring locks??
    Im looking for good aftermarket spring retainer locks that can handle 160-170 lbs installed to fit with a 7 degree set up!The locks I currently use are not holding up to the pressures at full lift!(about 380-400 lbs)Any help would be great thanks!
    Single honeycomb springs or duals? What diameter if duals?
    I guess I should have asked if you're using titanium or steel retainers. Stock locks are pulling through? If titanium, sounds like a bad batch a material.
    They are a dual spring! Im using chrome moly retainers!The springs measure 1.300" OD
