Results 1 to 9 of 9
Thread: T56 tranny 02 5.3
    Jun 2007
    maine
    T56 tranny 02 5.3
    does anyone know if a 1998 camaro ss t-56 six speed will bolt up to a 2002 5.3 vortec w/o a different bellhousing, i had heard that 2000-2002 would but maybe i was just told that because it was a newer year and was more of a reccomendation than a fact. thanks all
    San Marcos Texas
    It should work, the 1998 has the LS1 which is the same as your 5.3.
    Oct 2005
    As long as it came from an LS1 car and not and LT1 car it will fit
    Jun 2007
    maine
    sweet because i found one from and 98 ss camaro with 69000 miles on it. not to bad i suppose.
    San Marcos Texas
    Don't try to reuse a stock type clutch they are junk. Get a good aftermarket clutch/pressure plate.
    Jun 2007
    maine
    i am going with the ls7 clutch package from scoggy dickins i believe its 400$ for it all seems like a good idea to me and was also suggested by patrick. thanks pat! haha
    San Marcos Texas
    Quote Originally Posted by Wtfan18 View Post
    Nice set up for only $400!
    Be sure to check where the stick-shift will be located and that you'll be happy with it there. A lot of guys have had to relocate the shifter forward using the Keisler shift rail location kit. The kit isn't cheap but it makes it a more comfortable position to shift from.
    Check out their website for options... Street Rod / Kit Car 5-speed and Street Rod / Kit Car 6-speed overdrive transmission systems for Street Rod / Kit Car (Tremec TKO-500 TKO-600 T56) from Keisler Engineering
    Jun 2007
    maine
    yep already emailed them to get the kit to move it forward. 350$
